System fonts not showing
letterman7
Very Active Member
This may not be a directly related Corel issue, I'm running 10, and not all my system fonts are appearing on the drop down menu when I select the text. All the little tick boxes are checked in the options menu to show TTF and other fonts. It's weird, some won't show in Illustrator either, and it's always the same fonts. Tried loading them a couple of times; they appear in the font folder of the system, but won't load in any of the programs. Thoughts?
Rick
1234
Member
hi,
i´ve met a similar problem in higher version of corel on the other forum.
the reason there was that the user didn´t have installed corel capture,
which cause the problem.
not sure, that is the right one solution for you too...
best of luck!
