Teal 1/4" pvc
Yeah, never seen teal. You'll hafta paint it or wrap it. If you want 1/2' as a final size, why not just buy 1/2" stock ??
Is this inside or outside ??
Actually looking for 1/4". Inside. Needs to closely match directory panels inside a hospital. We used to be able to get it, but not now.
marunr
Looking for a source for teal 1/4" thick PVC sheets. Also, what adhesive might be best for gluing 2 PVC sheets together? thank you
I haven't seen teal either. We always print it if necessary. We also use Weld On #2007 and a syringe for gluing pvc, but you can use regular pvc cement from the hardware store as mentioned. Whichever way you go be sure to test it as the glue may dissolve the paint or glue. We usually leave the glue areas unprinted.
  • Informative
Reactions: 1 user
