Haakon
So a few days ago I got my secondhand S75D up and running, replacing my Roland GX24. I use SAI Flexistarter 8.6v2 as setup/cutting software. I've used this for the last 5 years or so (flexistarter on GX24). I'm pretty familiar with it and how the settings in the setup preferences work on the Roland.
After changing to the Summa (setup was pretty easy, disconnect GX24 from USB, connect Summa to USB and add the cutter/set up connection in production manager), it worked perfectly for the first job, but some issues afterwards.. I do not know if its Summa or Flexi related, so I'll just try to explain as good as I can.
1. First job it worked perfectly. When hitting the Poll Size button in production manager the work area adjusted to actual size and the file cut just fine. But after changing rolls and trying to poll size again, the production manager program crashes immediately after hitting the poll size button. If I don't hit it and just press send the file goes through and it starts cutting as it is supposed to. I don't know if this is a Hardware or Software issue, but it has never happened before the hardware (cutter) was changed.
2. I tried to cut a graphic for a mailbox, with smallish letters in a handwritten font. Even though the cutter was set at 500mm/second speed, it cut the letters very very slowly, but raced when moving between letters and lines. I tried with some regular text afterwards (Arial) and it cut it very quickly, like the 500mm speed setting would suggest. I made a video clip of it (the slow cutting) and will update this this post when it's processed at youtube.
Now, is is the software or cutter itself that controls the speed, cutting order etc? I've always wondered about this. Does the cutter receive the file as one whole set of data and decide itself where to start and finish, or does the program override this?
I do have a copy of Flexistarter 10.5 as well - it is brand new and uninstalled. But some bugs in either the uninstall wizard or the program itself (SAI production suite) won't let me uninstall it, it just comes up with "error 6003" and shuts down the uninstall process.
So what I want to achieve is this:
1. Make is so everything works smoothly, and that nothing crashes when asking for work area dimensions from the cutter.
2. Make it work at normal speed, not 50mm/sec when cutting and 500mm/sec when moving between cuts.
Video was uploaded while making this post (youtube flipped it vertically, so it may look like that while the video editor flips it the right way again
[video=youtube;UTIMdFiFCZI]https://www.youtube.com/watch?v=UTIMdFiFCZI[/video]
