Transferring settings to new main board.
IsItFasst
So I got a new main board but from what I understand the only way to get the settings transferred is through the peck6 software which I don't have. Anyway to do this?
Ragnabrok
It's not required, but it does knock a few hours off settings and alignments. Peck is used to pull the parameters, and put them on to the replacement. If you are replacing the main board, are you able to communicate with the old one? you can't pull parameters off a dead board.
Also of note, replacement boards do not come with a battery, or firmware.
IsItFasst
Yeah, I can pull information off the old board (machine still prints). The machine is working but I am having other issues that may be related to the board as it isn't printing properly after a board repair. I can pull info from it using copeck currently. Still not 100% sure the board is the problem but would know if I was able to swap it out with the new one I have in hand. I have done this before on a different machine. Can't remember how I did it as it has been several years ago (maybe a tech did it for me).
Ragnabrok
peck, no copeck, get parameters from the old board, put parameters on the new one. copeck doesn't have the get and put parameters buttons.
