I haven't tried this yet because I haven't printed anything new. I wil have to wait until Monday. The Graphtec guy told me not to use the standard reg mark setting in the "Cutting Master 2 " plugin, but to use the "Convert Rectangle" method to insure proper reg mark locations. You know place rectangle box around your artwork and base the reg marks off of that box. Here's the video link: http://www.graphtecamerica.com/imaging_video/Print_n_Cut_with_CM2/CM2Illustrator.htm
He also said my reg marks can be slightly off since I keep getting the Mark scan errors. Has anyone else run in to this fix. He also suggested scotch tape. Go figure. The damn machine should have a scotch dispenser on the side for just the occasion. Eager to get past this.
load the material in your plotter the other way and (since you are using the Cutting Master plug-in for Illustrator) rotate the cut file 180 degrees.
I had this problem before and found this sometimes corrected the problem. I suspect it was the Latex printer's high heat that warped the print a little.
Onyx 10.2 version will not support older Graphtec and Mimaki print to cut plotters! Found out directly from Onyx today!
I just had the sensitivity setting increased so that it would read through the lam. I was able to cut anything out without the lam so there lies the issue. Using the Matte Scotch tape did not work. I can't believe the manufacturer would tell me that kind of fix. Just turn up your scanner and all should be fine.
