trouble with EstiMates.
Valentino
I have having trouble with EstiMates.
i am pricing a 3" by 6" sticker, that has been set to a difficult cut.
quantity price
5 $50.20
10 $55.21
50 $97.51
100 $140.00
It's only charging 1.40 a sticker for 100, how do I change it to be about 7.00 dollars each for 5, and about 3.00 each for 100
Checkers
You can make adjustments several ways, but it depends on which plug-in you're using.
The easiest way with most of the plug-ins would be to adjust any combination of the sliders to get where you need to be with the price. Judging by what you're describing, I would adjust the "General Difficulty Level". However, the thermal prints plug-in has a contour cut difficulty slider too.
Checkers
GregT
You can override everything, and just put the amount you want in. Down near the sales tax box is a box to override. I don't normally use that, but its there.
Replicator
I agree with GregT - Just enter your items in manually as a free-form item
and give them the prices you want to for the quantities you want . . . DONE !
Doyle
I often do what replicator just mentioned, but you can also try un-checking the box that says "apply quantity discount". I have had the same problem quoting printed decals, it would quote a quantity of 50 at $1.00/ea and a quantity of 100 at .50/ea. I just couldn't figure that one out. More often on these quantity jobs, I figure out my time and materials and use free form to quote my price. Good luck!
bob
Part of being in this business is having at least a glimmer of a clue what to charge for what. And even better, even a simple understanding of why you charge what you charge.
It passes all understanding that anyone would blindly plug into an algorithm not of its own construction and just as blindly accept whatever it says. The converse is every bit as other-worldly; to plug into that same unknown algorithm and then want to argue with the results.
Nothing wrong with letting some program to the long division but you really ought to understand exactly what it's doing and why it's doing it. If whatever you're using pops up with something that causes to to wonder just how that could be you don't know enough to be there.
Valentino
I know exactly what I want to charge and I know exactly why i want to charge it.
you also said that you ought to know how the program works. well, that's why I was asking for help from fellow EstiMates owners, not your 2 cents
Valentino
oh yeah, thanks for your guys' help, I actually called customer support and we figured out it was my trimming charge. I only had trimming set to 30% and we figured that trimming needs to be at 80% for contours.
bob
And you know that I'm not and owner/operator of Estimate because...?
...because I think its approach is grossly flawed?
...because I don't use it?
...because I don't think it's worth the disk space it consumes?
...because I use what for me is a vastly superior algorithm that prices consistently, treats materials in a rational manner, integrates all of the petty nonsense, and is so simple that I can do it in my head?
If the truth be known, I have a copy. Some years back I loaded it and messed with it sufficient to develop an understanding of just what it was about. And because of that understanding, it fell into total disuse. After a rebuild and upgrade of the system upon which was installed it wasn't reloaded.
Vis-a-vis my two brown pennies... Regardless of why you might attempt to think as you do, try to wrap your cognitive tackle around this notion: You get to post things, you do not have any say whatsoever in who gets to respond and the manner in which they choose to do so. Nor should you.
