Need Help Two FC9000s do not cut the same.
CasaDeGraphical
At a bit of a loss here. Two FC9000-140s. Side by side in the same room. Same tools, same settings, same cut file. One cuts perfect. One barely kisses the material. Been through multiple calibrations. Multiple trial and error cuts. One works perfect every single time. One only works on thin materials. Like the pressure of the pen maxes out, but I put an entirely new carriage on and am having the same issue. I am legitimately at a loss.
If anyone has run into this, any advice would be appreciated!
Mike Paul
Super Active Member
Your blade may be adjusted too high in the holder did you try swapping them to see if that fixes it?
Make sure your sending pressure the same way either from the software or from the the plotter settings
  • Agree
Reactions: 1 user
DChorbowski
Pixel Pusher
What is the condition of the cutting strips? If one is old and worn or even worse cut through, your going to have problems with cutting depth. Have you tried swapping blade holders and get the same results?
  • Agree
Reactions: 1 user
