genericname
Hey all,
I have another oddity here. We're getting in a second Mimaki JV3, and in order to reduce the number of computer systems I need to have sitting by my station, I've been running tests to see if I can get two printers to print simultaneously through a single Production Manager, via Firewire.
To test, I've created separate setups for our JV3 and JV4 (the stand in for our testing, before the second JV3 shows up). I point both to their corresponding Firewire connections, one at Firewire_0 and the other at Firewire_2. No matter what I do though, I can't print anything to the JV3. The JV4 seems to take priority, and will print no problem, but when I send a file to the JV3, it'll show its printing percentage as being 0%, and the JV3's LCD panel doesn't display any indication of information being received.
Have any of you run into this before, or have a solution? There's a possibility that we'll just be switching to Onyx, but if this is a hardware conflict of some kind, or a limitation of Firewire technology, that won't help us much.
I've disabled antivirus and firewall software, swapped Firewire cables and Firewire cable positions, reinstalled drivers, rebooted numerous times, and changed the sequence in which I plug in and power up each printer. So far, nothing allows me to use both of them while hooked up to the same system, through Production Manager.
----Edit-----
Using Production Manager 4.6, as part of the PhotoPrintDX Suite
----Edit-----
