UCJV-330 installation guide
89222
Good afternoon, in general, we have an unpleasant situation, the boss found a new ucjv-330 with a good discount, as a result, the plotter came to us without factory packaging and incomplete set. in the set there is no installation manual, bottles with service fluid, wipers, wipes, what else is missing I can not say, as in the open access list of what should be in the set with the printer I can not find, but as I understand this list is in the launch manual, which we do not have. If someone can share the manual from the 330 series (ucjv, jv, ts), I would greatly appreciate it. With the list in hand, I will be able to make a well-founded complaint to our supplier
89222
All suppliers have the weekend, I just wanted to solve this issue as soon as possible, so that on the weekend I could ask our unscrupulous seller to send the missing items by courier. On Monday, two engineers will arrive to start the ucjv330 and maintain the 320ea, and it's clear that they will have the manuals, but I don't want to waste time. At least there's a chance that the missing items will be delivered while the engineers are assembling the machine.
signheremd
On the right hand side of the machine are two QR codes - scan them to access the manuals (they are electronic now, not printed).
Smoke_Jaguar
As a tech who has done installs, I have learned that it is probably for the better. Easy to screw up assembly even with directions.
We specifically tell people not to touch the printer before install. I've walked into too many situations where the machine is damaged with no way to prove it was the customer's fault or damaged prior to packaging or they filled the machine with a 6 color ink set but were configured for a 4 color setup and the ink mixed in the printer. Stuff like that. If you want any warranty to hold up, let the techs do the install.
Smoke_Jaguar
I get the feeling of anticipation seeing your brand new 5-figure priced machine just sitting there as you're paying for it. Installs are a guaranteed full-day ordeal. In my case, it can be an easy 2-3 days as I also take the time to train people on them. Seems regardless of brand, dealers will promise to show you how to do everything and it's usually left to the tech. Had far too many occasions where a printer has been in service for years and people only have a vague idea how to run it and maybe 2-3 profiles installed.
89222
In our case, the problem is that the supplier opened the printer's factory packaging and sent us the machine without it, as a result, there was a re-sorting, which was not included (vipers and service fluid), something turned out to be more than necessary.
But in the end, everything worked out, the engineers who came to the launch brought a viper with them, we have service fluid from JFX200, yesterday they collected and filled with ink, today they will adjust and calibrate
