Need Help UCJV300-160 – Magenta head won’t recover after cleanings (LUS-170/LUS-200 setup)
Brazen
Mimaki UCJV300-160 – Magenta head won’t recover after cleanings (LUS-170/LUS-200 setup)
We have a UCJV300-160. Magenta on Print Head 1 won’t clear up even after multiple normal/hard cleanings and recommended cleaning solution. Nozzle check still shows issues with Magenta.
Current inks: Print1: LUS-170 CMYK / Print2: LUS-200 White + LUC-170 Clear.
Tech suggested replacing the print head, but before we do: has anyone fixed a similar “one color won’t recover” issue by addressing cap top seal / pump suction / dampers / air in lines or doing a proper cap soak? Any specific part replacements (cap top, wiper, pump) that solved it?
Also—has anyone successfully swapped ink sets between Head 1 and Head 2 on this model (proper flush/refill) or reconfigured to a different channel setup without causing contamination issues?
Appreciate any proven steps.
Smoke_Jaguar
Try doing an air purge? Looks like you're mostly getting deflections which is a good sign of air in the head.
Langelot
Also, try Mimaki cleaning solution #16 (for UV heads only).
Buy the kit, instead of just the liquid, as it comes with the special cloths that one can use with this cleaner.
It is super aggressive and one cannot use regular swabs with it as it will partially dissolve the swab material (which can then further gum up the head) - use only those cloths...
It is really meant for Mimaki's PR200 primer (for UV) but it can do wonders on regular UV ink-channels as well.
Just fold and soak the cloth and hold it to the the head surface for about 30 seconds.
"Rinse and repeat" two three times folding the cloth to an unsoiled section.
Do not use this solution for a head-soak - it's just too aggressive...
If you don't get any changes in the number and pattern of the missing/deflected nozzles, and you've decided to replace the head, then try with the regular cleaning solution (#15) and swabs, but try a little "scrubbing action" on the surface of the head - at that point, as a last ditch effort, you won't have much too lose by "scrubbing"...
