Ucjv300 changed from lus200 to lus 175. Help needed
signguy85
Hey everyone i own a ucjv300 that had lus 200 inks, ccmm ykwhitewhite. I switched to a dual cmyk setup because white ink is difficult to maintain.
I've gone and changed to the lus175 ink set in the menu. I've installed new hoses and disconnected the old recirculating pump for the whites and made channel 7,8 have the same hose routes the cmyk does. Brand new lines, new valves by the bottles, flushed the bottle holder best I could.
Now I had white clogs in the clip fittings, hoses that I've cleaned. My idea is running some flushing solution through an old subtank into the white head to see if itll help. Also thought about doing a reverse draw, submerging the head increasing solution and drawing up with a syringe.
It was down over a month so may e ill be lucky but would appreciate any tips. I've been letting the printhead sit in a filled cap tops of thr cleaning solution 07 to help start the progress. Doing 24hr or longer
Smoke_Jaguar
Manual flushing of lines can cause some issues with subtanks, best to disconnect those lines and put the fittings in a place where they can safely drain into a container. I tend to tape open the ink valves and pour in rubbing alcohol to drain until it runs clear(-ish). Good to rinse out the bottle tanks. If there is a ton of white in them, you can replace those as well, but they run over $120 each.
Flushing solvent 7 tends to do a good job, but if lines are clogged, might be best off replacing the tubing. I just use a barbed union fitting and use the old line to pull in a new one, super easy.
signguy85
Oh yes I disconnected the lines from the subtank before flushing lines. Would i be ok to now run flushing fluid pretending to be ink in the former white channels to help the print head bounce back if it's clogged?
Smoke_Jaguar
If the head is clogged, flushing fluid might work, but it is far from a guarantee. One quick way to run a lot of ink through the head is to use the air purge mode and press FUNC2 when prompted. This will fire the head and you should see nice big drops of ink dripping out of the head. It uses a good amount of ink, but if using flush, that can be ideal.
How bad is the nozzle check on the head?
signguy85
Also rubbing alcohol or isopropyl? Might be cheaper than flushing with 1L solution 7 for that? I just replaced the subtank do you think I csn salvage it even if it barely any white. Were talking a month
signguy85
Last time I tried to do a test with the spot test it didn't do any white
Smoke_Jaguar
IPA/Isopropyl/rubbing alcohol, all same. 70-91% works great for a cheap rinse. Can still use flush if you want or chase the alcohol with it.
signguy85
Thank you. I wish for luck this weekend.
Also is there any way to run the air purge without installing the chips or at least run it in the hidden menu without it deducting ink % from chip counter? Want to run some flush to see if it helps but dont want to waste 1000$ of new ink lol
Smoke_Jaguar
Not that I know of. I tend to just order new chips if they run out. Since I only swap chips when forced to, I tend to get a decent sized pile of new ones. That said, never ran LUS-175, just LUS-170.
signguy85
Hey so I replaced all lines, swapped bottle subtanks to the new spots. Replaced 2 bottle tanks (whites) and i started up a d confirmed 4 color but it keeps going through the fill and ink type. Does it just go 8 times? Or do I need to power ofand/or change anything in the service menu?
It'll show cmykykmc and then go to ------mc or -------c
Also got a overflow channel 2 error 61a. Not sure why. New subtanks
Smoke_Jaguar
Might be having issues getting ink into the subtank. Also, make sure the sensors on the subtank didn't get switched around. Can go to #TEST > Sensor and nudge a magnetized screwdriver against the subtank sensors to see which ones respond and if they got flipped around. Happens a LOT as they aren't labelled.
Smoke_Jaguar
Just swapping sensors is a good way to nuke subanks by getting ink in the air channels. Make sure the sensors match the channels.
signguy85
Swapped em back. So overflow can also mean no ink supply? Should I disconnect a hose above subtank and use a syringe pulling some ink through? Might be all air right now because new lines but ill wait for your response bc id rather not damage anything... didn't know swapping sensors couod damage. It was only for a moment
Smoke_Jaguar
If you have a sensor on the wrong channel, it might be filling a channel to overflowing while the channel that is low is reading as being full. Check the service manual for channel layout and use sensor test to verify the sensors are in the right place.
signguy85
I am unable to access the sensor test. When I went into #test it prompted me with a single prompt to hit enter but wouldn't do anything after.
Also what's the trick to get to the #test screen without it booting you out? I power on, hold left and right, and if i hit end twice it never stays on that #adjust,#test screen.. it loads for a split second then exits out to place wait and does the start up procedure. I somehow got lucky the first time when I could click #test
signguy85
It appears the rear isnt taking in any ink. Im going to trace back wires from subtank 2 into circuit board and see if I can spot a pattern to fix subtank 1 overflow condition
