UCJV330 + CG130AR + IDCUT
idegrafik
Hi everyone, I’m based in Spain and I’m having a major issue with our Mimaki UCJV330 printer and CG-130AR cutting plotter.
This is my first time posting here. I normally try to search and read existing threads before asking, but I haven’t been able to find anything related to this specific issue.
When we purchased the printer, we also added the CG plotter as a backup for cutting laminated vinyl, so we don’t tie up the printer’s built-in cut function.
The problem is that using RasterLink 7 + ID Cut, the plotter cannot cut jobs longer than about 5 meters (≈16 ft / ~5.5 yd). The printer, however, can cut the same file perfectly, so the artwork/marks don’t seem to be the issue.
We’ve also tested multiple setups: we connected the cutter via Ethernet and via USB (same result), and we also tested with a different CG-130AR (not ours) and the issue still happens.
We’ve been waiting a long time for a response from our supplier, so I’m exploring other options. Has anyone seen a length limit like this with RasterLink 7 / ID Cut + CG-130AR? Any settings, firmware, connection, or workflow tips? Also, what cutter + software/RIP are you using for long contour-cut jobs (especially laminated prints)?
Thanks in advance, and have a great day!
When you say it can't cut jobs longer than 5 meters, is it cutting inaccurately or is it giving you an error code?
idegrafik
Hi! Thanks for the reply.
It does give an error code. What happens is: it reads the first registration mark, loads the ID Cut file, and then starts scanning the rest of the registration marks normally. But when it reaches around ~5 meters, even if there is no registration mark there, it suddenly goes back to the beginning (see attached image for clarity) and then shows a “registration mark read error” (mark reading error).
So it seems like it’s restarting the mark search at that length and then failing. Also, if we send a cut job to the cutter without using ID Cut (just a normal cut), it cuts perfectly. The problem only appears when ID Cut is involved.
That’s why I’m looking for feedback from people who have this machine (UCJV330) and who print & cut using other cutters and/or other RIP/workflow software (not RasterLink 7 and not the CG-130AR).
One supplier has suggested switching to a Summa cutter and using an Illustrator plugin to generate the required registration marks directly in the PDF we send to print, and then cutting directly from Illustrator. From what I understand, it would be similar to Mimaki FineCut. If anyone is running a workflow like that (or has experience with Summa + Illustrator for long contour cuts), I’d really appreciate your input.
Unfortunately, I've seen this exact issue with the ID cut on other models and I'm not sure how to fix it. The last customer of mine who had this issue called Mimaki directly and I believe they were able to get it going but never told me the fix. It's possible they didn't get it going and just lived with it too. We tried every setting we could think of and nothing worked. We even adjusted the sensor and motor voltages to make sure they were in spec and nothing worked. If you haven't tried already, try going straight to Mimaki. I know they've seen the issue before, whether they have a fix or not, I don't know.
  • Agree
Reactions: 1 user
idegrafik
Thank you very much for your reply. Unfortunately, the cutter has been with Mimaki since September 2024 and they still haven’t provided any solution.
We’re very disappointed with the support. It’s hard to understand how they can sell this as a package if it doesn’t actually work for long jobs — unless they only expect small sticker shops to use it.
Our main market is bus graphics, and we regularly produce pieces up to 14 meters long. Yesterday I already told my supplier that I don’t want the cutter anymore, so now we’re looking for an alternative solution.
As I said, I’m really disappointed with Mimaki after 30 years working exclusively with them.
Smoke_Jaguar
To be fair, getting a cutter that can track well at those lengths is going to be a pricey ordeal. The CGAR series is definitely not up to that task. That said, Mimaki isn't always great when it comes to their technical support. Might want to look into a Summa or Graphtec.
  • Agree
Reactions: 1 user
idegrafik
thanks Smoke_jaguar, we know the CG-AR series is not Mimaki’s best cutter, but the strange part is that we see the same behavior on another Mimaki cutter model as well. We tested with a CG-160FX II and the results were identical when ID Cut is involved.
Because of that, with our new supplier we’re considering moving to a Summa setup, specifically a Summa S Class 3 (T/TC) 160 with OPOS (Pro) Cam, which they say is the closest thing to a cutting table you can get in a roll cutter.
Our work is mainly long bus graphics, so we need a workflow that can reliably handle long contour cuts without hitting a hard limit like we’re seeing with ID Cut.
We would really appreciate it if anyone using a similar UCJV330 + Summa configuration could share their experience and opinion. We’re asking for real user feedback because, understandably, salespeople will always say their product is the best — and our Mimaki dealer said the same when we bought this setup.
Smoke_Jaguar
I believe ID cut has a max length/range that's probably either a firmware or parameter value. However, this is outside my experience and knowledge and Mimaki doesnt publish known values and annotations to the public or in their tech sites I can access.
Costaricanprinter
Voy a responderte en español para que sea más sencillo, no uso exactamente plotter de corte mimaki pero en las grapftec pasa que si no configuras el máximo de lo longitud en las opciones generales la máquina no corta las de 5 metros , podes verificar si algo similar pasa con el tuyo
Dicho esto y que tu proveedor puede cambiar el equipo te podría recomendar el GRAPFTEC FC9000 fácilmente podes cortar gráficos de 14 metros
Yo tengo una UCJV330 junto 2 grapftec y el proceso de corte es súper sencillo y preciso
idegrafik
buenos dias y gracias por la respuesta, el plotter está configurado a su máxima longitud, la misma pieza de 14 mts que con IDcut no corta, sin IDCut la corta perfectamente.
Por desgracia mi proveedor no me da ninguna solución y ahora mismo estoy negociando el reembolso del importe del plotter, complicado ya que la compra de la 330-160 y el plotter se hizo en la misma operación.
Aunq todavia no está decidido , la opción que estamos planteando pasa por un plotter Summa , aunque es de agradecer el saber que con Graphtec tambien es viable.
Podrías explicarme como lo haces? que software utilizas ?
Buen día !
Costaricanprinter
Buen día !
Puedo preguntar porque quieres usar el id cut si es una pieza de 14 metros, que tanto dificultad tiene cortar una y después enviar el otro corte
Yo produzco stickers o pegatinas e imprimimos rollos completos , con múltiples cortes de 75 a 100 cm por eso tenemos grapftec con el código de barras simplemente colocas el rollo y el plotter adquiere el corte correspondiente, claro esto en rollos de 30 a 50 metros
El proceso de creación del corte puede ser en Corel o ilustrador con el plugin para cada programa respectivo, tanto summa cómo grapftec cuentan con tal programa, ni las guías ni el corte de realizan desde rasterlink, el cual la única función que cumple es imprimir
El proceso es prácticamente similar para cualquiera de las 2 máquinas, creas el gráfico , colócalas las marcas de corte, exportas un archivo, imprimes y cortas después
idegrafik
no son repeticiones que suman 14 metros, son piezas que miden hasta 14 metros por unidad, marcamos autobuses y el cliente dependiendo del diseño no nos permite realizar juntas. Si pudiésemos hacer panelados , este problema no existiría.
