UCJV330 Epson 3200-U printhead lifespan
juki
Hello everyone,
Does anyone have experience with the lifespan of the Epson I3200-U printhead used in the Mimaki UCJV330?
I know it offers faster and more advanced printing technology, but how does its durability compare to the older “bulletproof” Ricoh Gen5 printheads?
Do you think Epson printhead will last more that 4-5 years?
Any insights from current UCJV330 owners would be greatly appreciated.
Thank you!
That model has only been out for about 2.5 years so there isn't going to be a lot of info on longevity other than early failures. Epson does state that the heads, "have proven durability and extended service life demonstrated by Epsonʼs own industrial printers." But no solid numbers. The DX7 heads were rated for 6 billion fires so these heads should be better than that. DX7 heads last anywhere from 18 months with some dye sub inks to 10+ years on some lucky people's printers. On average though, most people who print regularly and maintain the head properly see 3-5 years on DX7s. So this head should be better or equal to that.
Compared to the GEN 5 head, the i3200 is higher quality for sure but I would say more vulnerable to head strike damage. Your everyday small head strike won't be a problem but, in my opinion, the Epson head is more likely to get damaged in a bad head strike.
  • I Appreciate You
Smoke_Jaguar
Seen more issues on the i3200 than I would like. Mimaki's janky heater assembly might be causing some of the delamination issues. They do have the T3200 head that is designed for UV ink and heated, but Mimaki uses the i3200 with a heater strapped to it.
Both the i3200 and Gen5 have their ups and downs. The higher native DPI and insanely higher nozzle count on the i3200 is a winner on speed and quality. The Gen5 head is a tank, nice and durable and long lifespan.
  • I Appreciate You
juki
So personally, if you were mainly producing stickers and the price range is nearly the same, would you choose 300 or 330?
Ewan yu
www.printersign.com--Printhead,parts,supplier
One of my customers bought from me twice, about 8 months apart. But honestly, that’s not a very good reference because his usage is extremely heavy.
Smoke_Jaguar
I find the 300 series to be more reliable overall, but 50% of the repairs I do are on that model. Since it's been around a while, when things go down it's pretty predicable. The 330 is good if you're all about square footage per hour and you want really sharp, crisp prints. That said, you're talking about a $30K versus $20K printer. If on a budget, it's also much easier to find a good condition used 300 for around $10-12K whereas the 330 is kind of rare on the used market.
For me, the 300 ends up being the better deal as you can get 3 of those printers for the price of one 330 if you look around. Also, ink wastage seems to be far less on the 300 series. Since all 8 channels are on both heads for the 330 and it uses dampers, a head fill is going to have to purge all 8 channels simultaneously instead of being able to purge just one head (4 channels) at a time. Silicone wipers also last much longer and are way cheaper than the fabric strip wiper used on the 330 series. Not a huge deal, but consumables are a constant.
