Need Help UJF 3042 Mk II EX Error
wleong
My Mimaki UV printer is showing Error 528, which isn’t in the Operation Manual. Has anyone come across this before? I have to reboot the printer but it came back after a while.
William
Antony
the motor has a internal sensor to zero position when the pump is working and finish the sensor need to be in zero position when is not done you have an error....
this error is solved only replacing the pump..
JohnTom
Pumps probably one of the easier things to replace. Facing the rear of the machine it's behind the right panel. Other side of where you add the water.
