Suggestions UJF-6042 Mk II - Reviving
CES020
I could have sworn a started a thread when I bought this machine a while back because I had some help from several of you, but I sure can't find it in my posts, so I guess I'll start a new chapter.
Bought a used 6042 Mk II about a year and a half ago. Supposedly was running with a valid print test provided. It was said to have been flushed, but upon arrival, there was a massive amount of white ink running out of the bottom of the machine. I cleaned it up, started trying to get it going, ran into a few errors and got past some of them. I never got the machine to work. I installed a new main board (which didn't solve any issues at the time, I put in all new filters, replaced a couple of quick connectors and o-rings, along with a couple of solenoids that allow the ink to go down into the filters.
At that point, it told me I needed to install the rubber caps on the capping station. I didn't have those, so I bought those, then it would go to fill up the ink and it would alarm out and tell me the negative pressure wasn't right. I never could get past that point. Then I got really busy, and it's sat for a year or a maybe a little longer.
I had forgotten where I left off so I had to start all that over again and I'm stuck on that same place. I have run the tests that show the actual pump pressure and it appears that the pump is working fine. The next step, if I understand it right is maybe a stuck float in the subtank that's not telling the machine that the ink is in the subtank.
Here's where I'm at now, and I'm looking for some advice on if I'm doing the right thing or if I need to change my plan or add parts. At this point, I assume all the heads are toast. I'm willing to buy 4 new printheads and start fresh. My plan is 4 new printheads, all new filters, and all new subtanks. If I take that approach, maybe using a syringe to push cleaning fluid through the lines when I take stuff apart, should I be good to go? Or are there other parts I probably need to consider replacing as well?
I do, of course, have that sinking feeling that after putting all those on, I'm going to fire it up, put new ink bottles on, and then have it tell me the negative pressure is still not right (even though it currently says the pressure is correct in the diagnostics).
Thoughts?
Smoke_Jaguar
Sounds like a good day or two of a tech chasing things down and knocking out issues one by one. Just a lot of things to test but probably revive-able. Subtanks on those tend to hold up really well, but you probably are going to need some new lines. The 6042MKII is a nice machine, and great for small shops or moderate production of small items. If you're going in blind, you're going to have nothing but headaches and crazy expense. Heads tend to be pretty durable on those as well, so good chance the heads that don't have primer are going to be in decent shape.
CES020
I'm willing to try most any recommendations. You were one of the people that helped me when I got it, so I'm not sure where that thread went.
I have a 6042, with the cartridges, and bought this one to add to the mix. I did a lot of work on it to get it up and running but I never could get past that negative pressure error. The next step seemed to be to take the sensors off the subtanks and wipe them with alcohol. Not sure that's going to do anything since it's just a proximity switch reading a magnet in the sub tank but I'll try anything to get past that error. My current believe is the heads are bricked, or a head is, and that won't let it pull the vacuum to load the ink. Since I can't get it to print anything, and can't get past that step, I'm throwing in the towel, so to speak, and just thinking of replacing everything, but I'm certainly open to some more troubleshooting if you, or anyone else, has ideas on the next things to check. The negative pressure incorrect error doesn't indicate a specific head, and the diagnostics says the pressure is right where it should be, which makes me think the pump is working properly, but it can't pull the vacuum because 1) a head or heads are totally clogged, or 2) the magnet in one sub tank is stuck in dried ink and won't move so it's telling the system the wrong pressure.
However, since none of it is specific in the errors, I'm not sure where to go. I've spent a lot of time with it, a year or more ago, and I've changed the heads in my older 6042 so I'm not scared to tackle most anything.
I'm open to any suggestions!
CES020
What would you think would cause the error message on the negative pressure being off? It's error #61b. There are two tests to check it, one checks the negative pressure and one holds the pressure, looking for leak downs, if I recall correctly. It passes both of the tests within spec, but won't get me past that. That error comes up when I'm trying to load new ink with new chips. It tells me to install the rubber pieces in the capping station, I do that, and then when I tell it I have done that, it moves to the next step, which is clearly trying to pull a vacuum on the heads and it stops right there with the 61b error. No head specification.
Smoke_Jaguar
Lines might be bad, you're looking at a whole lot of troubleshooting, and I am not game to play forum relay for weeks. 61b is an ink supply issue, confirm ink is flowing in the first place before jacking around with circuit boards, vacuum systems, etc.
Tatonka
we got the 61b on our 6042 mkii recently, and it would dump the entire bottle of light cyan over a weekend because it apparently wasn't consistently holding pressure. Pressure tests showed fine while the machine was on. We replaced the air pump on the advice of our tech and that seems to have fixed the problem, but it's only been a few days since I put that pump in.
CES020
I know it's a stupid question, but how would I confirm the ink is flowing in the lines if I can't get past that error that allows ink to flow? Disconnect the lines at the subtank and then back above the filter and flush cleaning fluid through it?
Smoke_Jaguar
The most common area where ink solidifies is in the lines in the bottle tank area. Disconnect the filter, connect a syringe to the line, push in the ink supply valve and see if you can pull ink through. Black tends to be the line that solidifies first, but it can happen on any color.
