UJF-6042 MKII & MK1 Projects & Rebuild, Hacking, Etc.
btxmedia
This was a real problem for me ended up changing the UV lamps. Originally was very fast, and printing with Rasterlink only needed 6 passes @ 100% UV illuminance. Then after 6 months it suddenly stopped working and I couldn't get adhesion on the white ink. After checking & doing everything else - running a humidifier, fresh ink bags ($$$), using Red Hot or AP3155 promoter with no dilution, full head cleaning, new wipers, several white maintenance runs, etc - I had to dial it up to 12 passes. This was ok enough but slowed production down.
Then 4 months later the same problem happened. It had to be bumped up to 24 passes @ over 100% UV illuminance + extra passes to get white adhesion. Very slow! I figured the UV lamp was going bad even though it says it has 1300ish hours on it.
There is UV lamp test function on the printer but the test kit "OPT-J0250 UV-LED ILLUMINOMETER KIT ASSY" is something like $2,000+ when I found it for sale. And I don't know the reference values anyway. It is just a Hamamatsu Photonics C9386 UV meter if anyone cares to buy one.
I hate to just swap parts on stuff without diagnosing fully, but I took a chance and replaced the UV lamp (not the whole assembly or board) I got from TD Digital here at signs101. It worked fine again at 6 passes. The light coming from it was significantly brighter too. If you've ever swapped tubes on a water cooled laser engraver it's just like that - you're used to it's brightness on the undercharged tube, but then put a newly charged one in and it's like a supernova exploding lol - same deal here.
Here's a photo of the old UV lamps first, then the new ones. I am not sure if it's a new model or design because some of the gold trim is engineered differently, but the old/bad UV has physically smaller lamps. Did they burn out or something? Who knows. If this fails again I think the next step is replace the PCB in the lamp assembly, there are some gnarly looking transformers on it that could go out of spec.
Smoke_Jaguar
Slow, but getting there. Seems the thread got deleted, no notice or anything. Mostly been modifying firmware to just bypass the chip BS entirely.
Forty One
I just upgraded firmware for my JV33-160bs to V4.5 that included BS3 & BS4 ink types.
If you can work out how to include or unlock solvent inks, you're gonna be a ledgend.
But from my experience, the Mainboard is what will determine if you can run solvent inks. Apparently there's two versions of the board.
Smoke_Jaguar
On all the printers I have messed with made in the past few years, they all seem to share the same mainboard. I think the magic lies in the parameters. Currently turning a UJF-3042MKII EX into a 3DUJ-2207, and the trick was dumping the parameters and finding a way to down the locked down software. That said, can do some crazy things with parameters, so good to do it on a printer you don't mind potentially screwing up. Having donor printers on hand as well for parts is handy too.
The mainboard and slider are where the magic happens. The main handles most of the requests and interactions and then talks to the slider board. The slider is then what either communicates with a head board (or has head controls built in) and that does the actual printing. Mimaki build the printers as if they were kits almost, so there's a stunning amount of shared parts both mechanical and electronic.
Forty One
It would be interesting to watch the data that gets pushed during a firmware update.
I know there's a way by tapping onto the NVram for a 'live feed' but my audrino skills need to get past 'turn light off'.
