Stripeman
First off, yes, I do still run a couple JV3s....
My oldest machine is a 160s running 6 color config. I began having what appeared to be starvation issues. I noticed while printing 720x720 slow speed. I would begin to lose approximately 5 - 10 nozzles per pass, until pretty much, no print at all. A quick short clean restored printing. 720 x 720 high speed, seems ok, but will eventually drop black and light cyan (outermost printheads) but the other colors are good. I have some donor machines and have replaced: mainboard, slider(new), each printhead (1 at a time), power supply, both small IO boards, encoder sensor, encoder strip, printhead cables, mainboard to slider cables. I just cant figure this one out. Another quirk for informational purposes: When I swapped the mainboard, of course, alignment and head ID had to be updated. When printing x direction marks, it makes it about halfway through and begins dropping nozzles. Im pretty sure the printhead holds enough ink to get through this print, so it seems like a voltage issue. I did swap the power supply, but have not specifically checked the connections for actual voltage.
Any ideas would be appreciated..... Im getting a replacement for the machine, but its a battle of wills at this point.
