Actually...it does work. I ventured and gained. I have a homemade flatbed printer - Mutoh RJ900 and I run materials up to 1.5" thick - and it was my choice to stop there (and the length of tubing involved). So the problem was to rise the printhead to accommodate the thickness. The solution - to rise the printhead to accommodate the thickness. Two linear actuators, two linear bearings, one laptop power supply, a switch, some precise surgery and you can have a flatbed. And you still can use it as a roll to roll - just lower the head. The cost of conversion was about $800. So I'm able to print on ceramic tiles, glass, wood etc...with waterbased inks, but it's a different story altogether. Now, your printer is Mimaki, but
 I think any printer with straight media path should work. If you don't want to bother with much engineering, just put couple of spacers under the railing that carries the printhead - and you'll have the clearance you need - but only that - you won't be able to print on anything thicker or thinner than your coro height. As far as heat - you can post heat with an external heater. Her are some videos of what I've done to my  printer:
z-axis motion:
https://www.youtube.com/watch?v=oybTJP3kTp0
tile printing:
https://www.youtube.com/watch?v=2PyXcrOqC4g
Cheers!
