using a cast laminate on a 5 year calendered
gabagoo
I have read that you can use a cast lam on calendered vinyl but not the other way around.
If I were to use calendered vinyl and cast lam, would the cast help the graphic last longer?
I ask as it is a graphic that as to be cut up after and I really do not like using air egress cast films for that task, and I have no digital non air egress cast vinyl for printing on.
SightLine
No problems and yes, cast over calendered is fine, calendered over cast will fail. Also yes - the cast lam will extend the life of the calendered vinyl under it - especially if the cal vinyl under is printed. If it's unprinted then probably will not make a whole lot of a difference.
brush1
+1
