UV Printing on Glass Being Installed in a Bathroom
Susan Stewart
Good afternoon folks!
We are prototyping a glass wall hanging that is being printed 2nd surface on a UV flatbed printer. We are using on board primer, color and 40% white. Our concern is that it's going to be installed in a small bath room with a shower in it. We are concerned that the ink may have failure after time being exposed to moisture / steam from the shower.
Does anyone know of some kind of protectant that we could use on top of our ink to keep out the moisture?
petepaz
not sure that the shower moisture/steam is going to be any worse than outdoor weather conditions, extreme heat/sun/cold/snow
johnnysigns
Yeah, I don't think I'd worry too much about that as long as you test primer/adhesion promotor and you're satisfied with the testing.
signheremd
I would be more concerned about cleaners and detergents (shampoo, soap). You could always apply a clear or matter laminate over the graphic if need be.
JBurton
Signtologist
I'd be more concerned with what will be used to clean the panel, ammonia, bleach, CLR, all those things they use to strip soap scum. Just include cleaning instructions for mild detergent and water and you should be covered...
Pauly
Printrade.com.au
I feel like I'm one of the only ones here qualified to answer this question.
We print on glass every day for wet areas (Splashbacks, bathrooms, laundries etc and some outdoor applications)
Few questions.
What's the application of the glass?
A dividing wall? a splashback? or a decorative piece mounded with standoffs?
What brand is your printer? I'm assuming it's the Mimaki JFX200 according to older posts of yours.
If you're using the onboard primer. Have you tested the adhesion on glass?
A lot of adhesion promotors don't work on glass as the glass surface is too smooth. Or they appear to work, but in moisture they start to come off.
Why 40% white? Is it suppose to be some what translucent?
We paint all of our glass with specialised paint for glass instead of white ink.
We've found to this day, UV inks are just not durable enough for glass applications. (you can get away with it by doing multiple layers but this becomes a cost and time factor)
  • Agree
Reactions: S2S
Susan Stewart
Thanks for all your replies. It sounds like we should be fine.
We do send out cleaning instructions with our glass.
We are putting the glass in a frame, and it is hanging on the wall.
We are printing on a Mimaki JFX200-2513, and we have done multiple tests over the years for our adhesion. Our on board primer works great, and we haven't had any issues on glass.
We are using 40% white because it needs to be somewhat translucent. It may be back lit.
WhippetGames
Few questions.
Would you be kind enough to share what paint you use on the backing?
