I had the misfortune of encountering this error E085 head heat after a print head replacement. I have been printing with mutoh valuejet printers for the past two years and this was my first print head replacement. The change over was pretty straight forward but when all said and done this bloody error turned into a two day service mission. Through this site reading through post and suggestions I was able to narrow it down to two possible culprits. The first being the FCC print head cable and secondly the three small fuse on the Mainboard. I had a spare cable available which I changed over and ended up getting the same error. I seen in some forums the main board fuses may have been burnt because a faulty or unsecured print head cable connection. Sure enough with the aid of a multimeter test all three fuses were shot. Replaced the fuses and the machine are back printing like there supposed to. I suggest carefully and secure connect the print head cables to prevent any shorts in the main board when you startup the machine. I hope this helps anyone who encounters this error after a print head replacement.
