VCarve using Bobcad Depth question
DanBiron
We have had a little bit of success using Bobcad to set up our VCarve file but are struggling with getting it to maintain the shape of the letter. It seems that we have to enter a depth and what we enter affects how wide or narrow it cuts the width of a letter. Is there a way we are missing to get it to adjust the depth by keeping the witdth of the letters?
JBurton
Signtologist
Are you cutting with a V bit?
With a V bit, the deeper you go, the wider the cut path, the narrower the letter appears.
DanBiron
We are using a vcarve bit. The issue is we are struggling to figure out how to make the letters be the correct width. Is there a way to have the size of the letter determine the depth so that it cuts to the size of the letter in the file and lets the depth be whatever it needs to be?
JBurton
Signtologist
What type of CNC are you running?
So you have several factors at play, depth in the software, and depth the machine is set to. Your software knows you're using a vbit, so it will try to offset the toolpath to the text to achieve the desired width, which is dependent on the depth. Depending on what machine you're running, the depth won't necessarily be set where you want it. If it's an older/simpler machine where you set zero by hand, then it is key to make sure the bit is consistently set between runs, as it will change the width of the letters if not set consistently.
Is your problem making the files, or running the machine, or kindly both?
DanBiron
It's an older Industrial CNC and we do have to set the zero manually each time we use the machine. After doing some more testing we have found that if we set the depth in the software to half the width of the widest section of the letters it stays pretty close to the size overall. I am looking to see if there is a way in the software to have it simply use the shape of the letter to control the depth and not the other way around.
JBurton
Signtologist
Unfortunately I'm unfamiliar with Bobcad, and can't really answer that, other than to say that wouldn't be the best idea if you're doing repeat work for the same place. If you have an EXIT sign, all caps, you'll have a different depth than something with a serifed 'a'.
As far as setting Z on an older router, when I had mine, I would move the spindle close to the material with the bit very loose in the machine, then lower until the bit hit the material and slide into the collett some more, then tighten the bit in the collett while still against the material, and set Z zero there. This took a lot of guess work out of setting Z, but if my table wasn't level it didn't really matter.
