By "it" I take it you used the auto conversion tools that Corel has, is that a correct assessment? There might be one that may get it right or one that may be closer to getting it, but that's always a crap shoot. My go to is usually some combination of Bezier Pen - Primitive Shapes - Pathfinding Tools and try to ID fonts if it can be done relatively trivially as a first attempt. In all honesty, embroidery digitizing software has better tools for this compared to vector software (depending on what level of said embroidery software you have) as that's really what digitizers do (even if it's their own stuff) and why so many also offer vector services as well. But not anything auto conversion, they would be manual tools, just easier/quicker depending on the software one is using.Would the two vector softwares that are talked about in this forum clean this up to be usable? I try coreldraw and it didn't do well with this. Can someone give me there thoughts.
true. I'll use what I just used for Craig as a shortcut. And as a capable user of any software that supports vector.. Adobe illustrator, Correl draw, affinity, ink capes........... anyone with skills and capabilities in manipulating that vector output can further clean it up. Way faster solution when you're real goal is manufacturing.It really depends on how clean and detailed the original artwork is. Most vector software can help clean up the shapes and edges, but you may still need to manually adjust some areas before it’s suitable for digitizing. CorelDRAW can handle a lot of this, but sometimes tracing and cleanup by hand gives better results than relying on the automatic tools.
Be thankful you haven't dealt with auto conversion in digitizing software and as much as they cost(could buy a perpetual license for Flexi multiple times, well when that was a thing if I recall correctly) one would think those would be good.Way faster solution when you're real goal is manufacturing.
Beta, then there's a fee. Adobe already has it, but you only have so many "ai" credits. Depending on your plan. Then you have to buy more ai credits.All true... I often up-sample prior to the trace - and defiantly, always up the contrast then covert to monotone if colour is not involved/required. Apparently Corel is showcasing a "text to vector" and enhanced tracing features in the near future... I await with bated breath.
The only ones that would actually go up in price are going to be the more frontier models, the older ones would just get pushed down even into even the free tier. Of course, we do have even oss/open weights ones that can be run locally and without internet (hardware is going to be what gets them there). Eventually things will get more expensive, more locked down, but there will always be the cheapskate tier, that's how one sucks them in.Beta, then there's a fee. Adobe already has it, but you only have so many "ai" credits. Depending on your plan. Then you have to buy more ai credits.
Honestly I would like using ai to cost more so people would use it less.
Vectorizer.ai - 30 seconds. Need to fix the "O" in October, the little tail was so fuzzy the software didn't know what to do with it.
If you are after 'Free' try Inkscape - it has a respectable trace feature - I've also had success with the build-in trace in Lightburn.Thanks is it free software? Give me some more info on what u used please. Thanks!
It's like $10 a month. I can usually do the same with what you had in illustrator using trace, but the time spent dialing it in an fixing... I like this short cut.Thanks is it free software? Give me some more info on what u used please. Thanks!
