Vectorization
Pala-gurl
Hey does anyone here kno how to "vectorize" a picture from like google into a winpcsign program.....just want to play around with the pic but i dont kno what vectorize means or how to do it
mladams7259
Send the file to the vector doctor. He does excellent work and has great prices. Vectorization can be done manually many different ways. Programs like corel have an auto trace tool built in that will vectorize an object too. Considering that you arent familiar with how to vectorize an image I would contact The Vector Doctor
His website is www.vectordoctor.com
Kerrylim
If you have a high enough version of WinPCSign, it has vectorization capability (WinPCSign Pro or higher). Adobe Illustrator and Corel Draw both will convert images to vector and if you have either of these, pick up a book that can show you how to use the tools. Or - as everyone else has suggested, use the Vector Doctor.
threeputt
Vectorize simply means converting an image that is comprised of many, many little squares of color called pixels, to a lot of closed path shapes. Each shape overlying others. (each shape is manipulatable of and by itself.)
Start with simple images and mess with your design tools. Read up in the tutorials or if you have on-line help, that's even better.
Baby steps, my friend. Good luck.
mark-s
You should have a disc that came with your program and a manual that will
walk you through the process.
