Do you have the "Include Contour Cut Paths" box checked (in the dialog box that pops up when you send the job) in each case? Next, if any of your contour cuts are inside of a mask, or grouped with another layer (color) they often are not recognized. First thing to try is to select the item with the contour cut and ungroup it. If that doesn't work, right click over any masked item and drill down to see if it has a contour cut hidden down there. While Flexi doesn't make it obvious, it works with layers as do Adobe Illustrator and Photoshop. The Contour Cuts are to be on their own layer. When working in Illustrator, all contour cuts should be on the magenta layer. Hope this helps you figure it out.
