versaworks with graphtec
evie
I have an RF 640, and want to use my plotter (sign warehouses version of the graphtec 54"). What do I do to print with versaworks and plot on my generic plotter?
GAC05
Quit buggin' me
It looks like Versaworks will only run Roland plotters.
If true then you need to use the software that came with your cutter to set up the contours and crop marks.
What app did it come with, LXI something?
I have a Graphtec cutter and use the generic app(Cutting Master) that it comes with to do the contour of prints that come out of Flexisign.
(I could do it all in Flexi but it is easier in Cutting Master).
Basic workflow is:
Design in Corel or Illustrator
Use the Cutting master plug-in to set up the crop marks.
Export the file to be printed to Flexi's production manager (with the contours set to not print)
Print and lam - load into the cutter.
Use the contour and crop marks in the original file to run the cutter.
Done.
Should work about the same with Versaworks.
wayne k
guam usa
evie
Basic workflow is:
Done.
wayne k
guam usa
It came with LXI, I will give this a try...Thank you
