VG2-540 Magenta Channel Not Working Correctly Where White Channel Has Circulation Pump and Extra Solenoid Choke Valve.
graphicsphere
Custom Signs & Graphics
My VG2-540 Magenta Channel is Not Working Correctly Where the White Channel Has a Circulation Pump and Extra Solenoid Choke Valve.
I have attached my Nozzle Test Print that shows the problem. The Magenta Channel is where White Ink usually is installed but because I don’t use white ink I use a Magenta Cartridge instead and set my VG2-540 to use 7 Colors.
In the Service Manual I followed shows to have the circulating line go into the bottom half of Head 4. This is causing all my issues it seems because all my other Color Channels don’t have any problem. Is there somebody that can show me how to correctly hookup the Magenta Color Channel for Head 4? Is there a way to completely bypass the Circulation Pump and Extra Solenoid Choke Valve so that Magenta Channel works like the other 7 Color Channels?
