graphicsphere
I'm getting the service call 0380 error on my VG2-540. I checked dampers and suction pumps in the front cover and all appear ok but some of the ink lines coming out of the pressure pumps in the rear cover look like there is no ink flow and then two of the cartridge slots blink saying to remove and reinsert the cartridges which I think means two of the pressure pumps could have a clogging problem. I put cleaning cartridges in those two slots but still no ink flow from the pressure pumps. The service manual recommends doing a pump up to replace the pressure pumps which I don't think will work in my situation which is why I wanted to ask before I do anything. When you do a pump up with the VG2-540 does the printer ask to remove all the cartridges and then it pumps all ink out of the ink lines? Does anybody have a video on a pump up or can explain what the pump up does? In my situation if two pressure pumps might have a clog than doing a pump up can't be performed right? I just want to know before I go in and pinch the pressure pump lines with forceps before removing them.
