VG3 Error Codes once a day
FORMATMOTO
Hey all,
what typically do these error codes indicate and what is the fix for them?
0002[0040] has happened 4 times
0002[0041] happened once
My machine is BRAND NEW and just had three print heads replaced.
FORMATMOTO
This happened before and now after the print head replacements(all codes besides one 0002[0040] after print head replacements)
First off if it is brand new, your printer is under warranty. You have a one-year warranty if you purchased it here in America. 0002 error is for communication between the main board and servo board. The technician needs to be reseating all of the cables on the main board and server board. I got a step further and do it on the print carriage board as well. This time of year when it gets cold, there’s a lot of static to build up. Many many service calls are just resetting the cables. This is something I have learned over 15 years.
I am putting it out there with everyone. you’re not my service over area so it really does not matter to me.
So reseat all the cables on the main board, servo board, junction board that is in there as well everything that you see when you open up the Chassis
you’re a Roland technician should be doing this under warranty.
Also disconnect the ethernet cable and see if these issues still arise
this is years of experience coming to you at no charge.
and for service call 0002 or there really should be no sub codes. Are you 100% certain you’re getting a Service Call 0002
victorn
Hey all,
Did you ever get a solution on this , we have the exact same issue.
