VHB tapes for mounting 3 dimensional
Wilk
We use a lot of VHB tape for lighter applications instead of stud mount or adhesives / silicones when mounting 3 dimensional graphics onto backer panels or walls. We use tape because it's more convenient and we don't have to worry about applying too much adhesive that might squish out when pressure is applied.
Now, we've had some letters fall, I assume it's due to not enough consistent pressure being applied for an extended amount of time (especially on walls). To deal with our trust issues we'll use a thicker "foam" style tape, problem with that is it raises the letter more than we like...does anyone have an aggressive high bond double side tape they like using that's thin. Substrates are usually acrylic, ACM or foam.
tulsagraphics
Tape usually isn't the problem. It's the paint you're mounting your letters to;. Low or no-VOC paints are stain resistant (which means adhesive resistant properties), and that's what a lot of paint formulations are these days. You might get things to stick for a while (weeks, months) -- depending on what the customer decided to paint their walls with. if it's a newer paint formula, expect some eventual failures, especially with the added weight of dimensional letters (compared to flat vinyl graphics).
If you really want something to hold up -- skip the l̶a̶z̶y̶ (I mean, "convenient" way). You've got the equipment for it -- just optimize your workflow and stud mount everything.
Reactions: 1 users
