Vinyl Express R series II
sdtag01
Hey everybody,
Newbie here, first time poster.
I just wanted to share my experience in case it might help some others.
I have an old Vinyl Express R series II cutter/plotter. I haven’t used it in years. I remember it had some kind of proprietary software that was very anal about being protected from multiple installs. Very paranoid and a little annoying.
So anyway, we just moved and are getting all settled in and I drug out my old toy. I still have the pc with the proprietary software on it but it’s getting old. It’s running Windows 10 and all the rest of the computers on my home network are running Windows 11, so I wanted to see if I really needed the proprietary software.
I have a Windows 11 computer that I use for my little 3018 cnc laser engraver and I wanted to use the same pc for the vinyl plotter/cutter. I re-purposed an old Plex media server. This pc is no powerhouse by any means, but it is good enough and gets the job done.
I researched on line and found Vinyl Master and Easy Cut Studio 6 software. I downloaded and tried out both. I found Easy Cut a little easier to use than Vinyl Master. I found some others too, but I homed in on these 2 apps.
I ended up paying 60 bucks for Easy Cut Studio 6. It works great with my old cutter. I am happily cutting away once again. It has a pretty low learning curve and it supported my old plotter right out of the box. I can import and then trace jpg files. Wohoo!
And speaking about being paranoid about multiple installs, Easy Cut lets you try it out in demo mode, but it runs 2 slices through your work at the end, because it is in demo mode. Lol. After paying the ransom, the 60 bucks, it cuts perfectly without the 2 extra slices.
So to recap, I don’t need the proprietary software with my old Vinyl Express plotter/cutter. It works great with Easy Cut software. In case anybody runs into a similar situation.
