Vinyl perforator
JAKES GARAGE
A question, we make MX graphics with our Edge and are looking for a perforating system for the shroud portion for the older bikes and would like to buy a unit to do this. We use our plotter to do this currently but it takes forever. Also does anyone know how to use a GS15 to diecut out a decal as well ? Would you do a multi cut with different blades/pressures ?
JT
TresL
Same here.
Call the guys at GMS, the convex samples are Die cut, Kiss cut & back slit.
All done on a Gerber.
Where in TN are you you?
TresL
Graphics need high bond adhesive with 12mil overlam.
The perf holes must go through both to allow the tank to outgas fumes.
JAKES GARAGE
TresL, I know there is something used in another application that will work. I don't think everyone who does this has to have one of these custom designed and then made. I just can't figure what else they are used for.
Thanks Fred for your reply also.
