soloinstaller
Hey everybody. Today I removed some decals from a trailer and ran into some issues. I showed up with an eraser wheel and some 3m adhesive remover thinking that I'd get through this job super quick. However after testing the eraser wheel in a small area it appeared to create a permanent smudge, which I think was the clear coat being damaged. I didn't have this issue before. The trailer had a nice metallic paint to it. So anyways I took the longer route and used a heat gun to peel the vinyl off.
After that I figured I would go ahead and spray some 3m adhesive remover to get rid of the glue as I had done in the past- but after testing in a small area, this time it stains the paint also permanently. So I just ended up spraying with soap/isopropyl solution and blasting the glue with a heat gun while rubbing hard with a cloth. Ended up taking nearly 5 hours.
Any suggestions on how I can effectively approach this issue next time around?
