Dean Dos
Just got a used VJ1638x, there was an encoder error which I have fixed. ran a nozzle check, and printhead 2 was clogged, tried cleaning multiple ways, but only got it to fire 1 nozzle partially (magenta). So figure can't break that is already broken, got a little more aggressive with the clean.
Took the printhead out, removed the dampers, and let soak the cleaning solution overnight. In the morning, put it all back together, and now it is coming up with a Head Temp 2 error. Removed the printhead to inspect and noticed that while I was blowing out and cleaner from the connector I damaged the ribbon cable on the head.
Well - my bad - So I ordered a new Head, from China (a lot cheaper) and installed the new head, and now comes up with a Head Heat Error. After research, I found that there is an encryption code that you need to put into the printer. The new printhead is wrong only has a 7-digit code, not an 8-digit code.
Went into Parameters and shut off the Head Heat check. This allows me to start up the printer, and run a nozzle check, now both heads don't fire a drop.
Question - shutting off head heat, will this cause both heads to not fire at all, or is it just not firing because the printhead 2 has bad encryption?
Question 2 - is there a way to shut off Printhead 2 at start-up, to be able to print with only Printhead 1 - right now it will not get past start-up with Head Heat Check On
Any thoughts would help - if anyone has access to a full-service manual that would help greatly
