VS 640 Internal Error
cadillac531
Hello:
I have a VS 640, and I just replaced my wiper. Easy enough to do. When I finished and the machine was cleaning itself, it popped up a "Service Call 0109."
I removed the right cover and started to push the carriage over towards the right side. There was some movement underneath the head and then a saw a small spring fall off.
I turned the machine back on and received an "Internal Error 1220387".
I can't seem to see where this spring goes and can't find any info on the error. Roland and my dealer are closed today, any ideas here?
Thank you.
Constantine
cadillac531
No worries, I fixed it....
The spring went to the top, and I figured out that after replacing the wiper, the mechanism was out of timing by 180 degrees.
After putting it back in timing...it all worked fine.
Thanks.
