Wall Vinyl Install
ham1056
Hello:
We do a ton of window perf & vinyl install, some wall cut vinyl logos or lettering but doing an estimate on a 200 sq. ft area wall vinyl install. Straight forward area, no curves or angles, just a long wall. We have asked client to prime paint the wall but any other tips on wall installs compared to window vinyl? Trying to make sure I have install costs covered.
Eco-sol printer & Avery product
ChaseO
A Wall vinyl like phototex is much easier to install if there is no contours.
  • Agree
Reactions: 1 user
ikarasu
Hello:
If they prime it first, wait a few weeks for the paint to dry and Cure to the wall. Make sure they don't use an easy wash, low VOC paint. Do a small tape test and make sure the wall paint doesn't come off with regular masking tape.... If it does then you'll probably pull down half the paint if they ever remove the vinyl, and odds are your vinyl will curl and fall down on the edges.
Oh, and don't cheap out on the vinyl. Use Avery wall vinyl.. even removable vinyl will tear chunks of the drywall off when removing it if they ever do.
  • Agree
Reactions: 4 users
unclebun
Make sure they don't paint with paint that repels everything. That makes it so vinyl doesn't stick.
  • Agree
Reactions: 1 users
Martinc5
I install for a local company and they switched to high tac vinyl for walls about 2 years ago. Positioning has to be spot on before application as you only get one shot at it and it makes a mess of the wall if it's ever removed but had a lot of problems with normal vinyl in the past.
  • Agree
Reactions: 1 user
jfiscus
Rap Master
What vinyl & laminate are you using? Is it an interior or exterior wall? What type of paint/primer? There are a lot of factors that go into successful wall wraps.
ham1056
Interior wall vinyl is Avery MPI 2611 with over lam. I was going to have client prime the wall before install, wait a few weeks but may test with what they have & see how it hods for a week.
