WANTING SOME INPUT ON HP SCITEX FB700 HYBRID PRINTER
AI printshop
HEY MEMBERS, IM LOOKING INTO BUYING A USED BUT IN VERY GOOD CONDITION AND WELL MAINTAINED HP SCITEX FB700 PRINTER. I WANT SOME FEED BACK ON THE MACHINE, IF IT IS WORTH IT OR MAYBE LOOK INTO OTHER OPTIONS. I HAVE A HP LATEX 560 THAT PRINTS WONDERFUL. LOOKING INTO A FLAT BED TO SPEED UP PRODUCTION ON FOAMCORE, CORO PLAST, ACM AND OTHER SUBSTRATES TO ELIMINATE HAVING TO PRINT ON VINYL THEN LAMINATE THEN APPLY TO SUBSTRATES. SO YEAH ANY INFO/HELP FROM MEMBERS THAT HAVE USED THE MACHINE AND LOVE IT OR HATED IT AND SWITCHED TO A DIF MAKE AND MODEL OF FLATBED OR HYBRID PRINTER WILL BE VERY MUCH APPRECIATED.
Smoke_Jaguar
They're really starting to show their age and as such parts are getting scarce and very expensive. If you buy it working, count on running it as long as you can and saving for something more modern.
dtfonestop
Smoke and dasigndr are right about parts, so if you do look at this one, go in with a plan for what it'll cost to keep it running.
Coro, foamcore and ACM are exactly what a hybrid is good at, but make sure you see it run your own boards, not just the seller's demo. Thin coro and slightly warped foamcore are where feed problems and head strikes show up.
A few things worth checking in person:
- Ask for a fresh nozzle check on every channel and the service records. Heads are the big-ticket item, so find out which ones have been replaced and when.
- Ask what curing it uses and how many hours are on the lamps, since lamps are a recurring cost on older UV machines.
- Have them run a real job on coro at production speed and look for banding and registration drift, not just a nice sample.
- Before you commit, get actual quotes and lead times on heads, lamps and ink from whoever would service it in your area. On a machine this age that usually decides whether it's a deal.
- Budget for rigging, power and a tech to set it up. Those add up fast on a machine that size.
Roughly how many boards a week are you printing, laminating and mounting now? And what part of the country are you in? Service coverage for older machines varies a lot by region.
Smoke_Jaguar
If it's the unit that is sitting in some guy's yard for the past 4 years, avoid that. He says it runs, but the rails are rusted solid.
