Wanting to Buy a FC9000 Main purpose is MX graphics and perf cutting stickers- ADVICE?
FORMATMOTO
Hey guys, I have a GR540 that works great for cutting my MX graphics, but I want a cutter that will perf cut stickers well. I generally print sheets around 40-50 inches and my GR540 will not perfcut the way Roland advertised as it should. Any advice on materials/brands/settings that work well with the FC9000? Opinions?
BigNate
if you are not happy with how the Roland plots cuts, what makes you think you will be happier with how the Graphtec does it? actual process is very similar.... what issues are you having with the perf channel on the Roland? it may be the same issue on the Graphtec - many users I know don't use the perf channel at all, they just set the blade-depth very accurately and use the cut strip... (personally I use the perf channel, but I have quite a few hours testing different situations on many different medias -- most of your problems may go away after just a lot of experimenting/learning your specific machine)
Boudica
This may not be helpful, but we had that machine and we hated it. I also could never get the perf dialed in. That was only one of many many issues we had with that boat anchor. Terrible investment. Boss eventually got a Summa which I love.
LOL, got the perf dialed in pretty well on the Summa, but we almost never do the perf cuts now that I've gotten it to work. Mainly because perf cutting in general has it's own issues like not breaking clean all the time, or breaking clean too soon like while it's cutting then there are holes and it gets jammed up etc... It was decided by our small crew that it was faster and easier just to cut them down.
mdowner217
Get the cheap blade and blade holders off of eBay with an FC9000, into the perf channel, set it in the eye tool at about #7, 30 on the pressure. Perfect for less than 4” stickers. Anything bigger then you’ll need a perf cut line.
These blades aren’t gonna work on MX graphics tho. I used to have 4 FC9000 until we switched to Summa Flatbeds. There’s a company in the UK that make one that will last about 20 kits. The OEM blades will even blunt or break within 2-3. That’s doing a 2 pass cut to get the faux die cut with tables front and rear.
If the workload ever gets too much, we are a wholesale only manufacturer of moto graphics, with locations in USA, UK and Europe. No tariffs and 24h turnaround.
jharler
We had this issue with our S3 where some cuts would be deeper than others. Turns out the rail the cutting head travels on was not perfectly parallel to the cutting surface. We had to loosen the bolts holding the rail on and adjust it at certain areas. When adjusted, the cuts are perfect. We have a test file that we run that just cuts a row of rectangles that we can check for accuracy. We run it every morning and adjust the rail as needed.
  • Informative
Reactions: 1 user
FORMATMOTO
Nate, There are known inconsistencies with the GR540(first version) The perf Channel doesn't help with perf cutting on this machine. This is why I am asking if anyone has settings/materials they use with luck? I have tried to talk to so many techs(Rolands direct support on this cutter was a joke), used so many different blades and countless different types of materials with NO consistency. I see people have great luck with Summas and Graphtecs which is why I am here asking. I know the function is similar. Roland had tons of issues with this cutter, thankfully mine cuts decent when NOT trying to perfcut. However, I have seen many people have X/Y axis issues with the GR540. If I didn't have clients that wanted stickers perfect I would be fine, but I have lost business because of not being able to perfcut which seems silly as backers get thrown away, but I am not my clients so? If you would share materials, laminates and pressure you use for best results on your GR540 for permuting I would be appreciative!
FORMATMOTO
We run millions of stickers through our FC 9000. We don’t perf cut at all.
What materials(printable/lam) and pressure/speed are you running to get your stickers to fall out of the sheet in that matter then, Isn't that perf cutting? So the tabs stay on the sticker but you can pull them out? I dont want to seem ignorant or is that what you would call a through cut?
