Watermarks
RiXaX
Suppose that we wanted to generate a transparent watermark to lay over an image to send to a client. How would this best be accomplished?
Drip Dry
I would create my watermark and then put a lens from the effects menu.
You can set the opacity from there.
I always generate a 72 dpi jpeg for a proof. I scale down the image size to
about 12" wide before I export it to the jpeg. This makes it readable so the customer doesn't have to scroll around the screen to see it and if someone
tries to make it larger and print it, than it will be unusable.
Flexi has an export function to a PDF, and this would seem to be a great
option BUT... it includes all the vectors with it. So, if someone is trying to steal your file, you may as well send them the EPS file.
James Burke
I just import my logo, adjust the opacity to where it's just visible through the proof and then export as a jpeg.
James Burke
Export to a .JPEG first, then convert to a .PDF so no vectors remain.
