Need Help Weird artifacts around printed image
ringocat22
Not sure if this is the right forum but I'm starting here since it's a printed image. Customer sent me an image of flowers, transparent png file. On my screen it looks fine, no weird outlines or anything. But when I print them, there is an odd sort of outline or artifacts around the image that I don't know how to get rid of. I don't think it's related to the contour cut, they print with it regardless if there's a cut line or not. I imported the file into affinity to see if there were pixels just too light to see, but there's nothing there.
Has anyone else seen this, and is there a fix? I'm in Flexi, printing through Versaworks on a Roland Truvis 30". Photos attached for reference. It's happened once before, same thing. Is it an AI image issue or a printing issue? Any ideas?
ringocat22
Answering myself in case anyone has this same issue - Versaworks imports files as eps images, which messes up transparent png files. I tested exporting the file as a pdf, then importing it into versaworks and it seems to have solved the issue. So, an extra step but solved I guess.
Boudica
you could also try flattening the file and saving it as a tiff. I never even try to print png files
  • Agree
Reactions: 1 user
