Weird Drying on 2513 EX
Adam Vreeke
Knows just enough to get in a lot of trouble..
I am using our JFX200-2513EX machine to run some wood awards we do. We use LUS-120 ink set on that machine. This is my first time running wood on our EX (works wonderful on our normal 2513 with LH100 ink). I did a test one that turned out great with no issues; however, when I ran the first bed of awards the first inch or so shows signs that the ink did not dry correctly. We use an under base of spot white in places on the award so printing started at the back of the machine and worked forward to the 0, 0 mark. The "runniness" of the ink only occurred on the first inch or so of the table.
I have made sure my lamp position was in the correct spot (both lamps at 65), and all 4 lamps appeared to be firing. Has any one any idea what may have happened? 20250815_091917.jpg
White Haus
Not a Newbie
It's like the ink is bleeding/running into the grain before it's cured, which is weird if lamps are engaging when they're supposed to. Not like they need a warm up time given the fact that they're LED.
We've printed wood on our Oce Arizona a fair bit and have never had the ink bleed, then again Mimakis seem to lay down a fair bit of ink.
How big is that whole thing? That happened across the whole bed? Are you running multiples w/ a jig or template? Can you add a test shape/file before the actual job prints to see if kicking in lamps earlier is a work around?
  • Agree
Reactions: 1 user
Adam Vreeke
The words are about 6" in length. I got them 10 up on the bed printing the other pieces of the award with this printed via a jig.
I thought about the ink running, but it happens no where else except the first inch of printing on the first boards.
I got the job done already, was in a rush to get it out the door, but I ran the piece you see separately. Since there is no white on this piece it starts at the 0, 0 point and works back and did not bleed this way doing it like that.
I print other awards with a white under base, mostly PVC or acrylic and never had this happen before on those materials.
Smoke_Jaguar
LUS-120 does some weird stuff when it comes to wicking into wood, seen that before. Try putting down a really thin layer of clear lacquer first to cut back on it?
Adam Vreeke
The thing that is confusing me is that if that were the case, wouldn't it happen through out the printing and not just on the first inch of printing?
I will run the lacquer idea past the powers that be, but we have been offering this product for at least a decade and some customers have been ordering these every year. So a little hesitant to change things up on them unless everything else has been exhausted.
Smoke_Jaguar
Can also try heat or plasma treating to see if it makes a difference, could be some sort of material contamination causing the wicking.
Find one that is wrecked or a scrap piece, toast it gently with a heat gun and see if it does better in printing.
LP_UV
That is definitely the lights not being on (ink not curing). We have seen it before here when the lights malfunction once in a great while and do not come on. We do not use white or undercoat so I have never even seen one of these machines print backwards (towards 0,0). However I am guessing that these are at the very end of the 'run' and the machine for some reason either: a) the machine does not progress far enough physically in the reverse feed direction, or b) the lights are shutting off prior to fully going over the end part. Can you try putting them in the middle of the jig and/or adding a small dummy image at the end (towards 0,0)?
