Mike F
We've got a Royal Sovereign RSH-1651 hot/cold laminator. I was using it a few minutes ago to mount some stuff, and I had it set to cold mode. After mounting a few prints, I noticed that I felt some heat coming from the machine, and the rollers were hot. When I hit the temp check button, the top roller read 180 degrees Fahrenheit, and the bottom was 80 degrees. Even weirder, when I switched over to hot mode to check what the temperature settings were there, the top roller was only set to 120. I've used it quite a bit and this is the first time this has happened. Any idea what could have caused this, and/or how to prevent it from happening in the future?
