Welding on steel poles with digital price sign attached
amer2828
Hi, and thanks for any help. Sorry if this has been answered before. I know the stock answer to this would be "don't weld on steel freestanding sign poles while there's a digital board is attached". In simple terms I have to, because of the way the freestanding sign is built and the way the digital board comes from the factory. On all specs I have ever seen from manufacturers is "dont do it and do it at your own risk" I know I should demand a signature that we're not responsible for any electrical or electronic issues. Would you do it? If so and if it's normal and easy - how? Is there a normal procedure ?
JBurton
Signtologist
Never had a problem with it here. Don't put your ground clamp on the digital sign, put it on the pole. I've seen more warnings concerning blocking ventilation than I have about welding with sign attached to structure. Just went through the last set of Optec drawings we worked on and didn't see anything in those.
SmartLED_Inc
JBurton's ground-clamp advice is the most important part: keep the clamp on the pole, never on the digital cabinet.
A few other habits that have saved us some headaches. Kill power to the display at the disconnect before you strike an arc, and leave it off until the metal has cooled. Welding current can still find its way through the cabinet skin into power supplies, receiving cards, and data cables, especially if a module frame or data line is bonded to the structure. If you can, unplug the main power and data whip at the cabinet during the weld, or isolate the cabinet with a dielectric break if the design allows it.
Afterward, power it up and walk the face. Look for dead modules, color shifts, or a card that will not come back. Also keep slag and blankets off the intake vents. A lot of these price signs fail from blocked airflow, not from the weld itself.
I should mention I work for Smart LED and we manufacture LED signs, including fuel and price displays, so this comes up on installs more than I would like.
