What does everyone think??
jwash
Here is a logo I am working on for a small contruction company. They want a graphic image that relates to the field and RED. They like red. The logo will be used on site sign, business cards, and truck lettering and t-shirts. The man hammering is a bit simple but the client liked it because it didnt take away from anything else, but I would like to see something else in there. So if anyone has any please let me know.
thanks
jwash
Small Lettering
SmallLettering.com
Very nice design. I find "PRIMIANI Construction" a bit hard to read. I think I'd reverse it- "Primiani" on top in the script, & "CONSTRUCTION" on the bottom in the all caps. You might also reduce the size of these down just a bit to give it a little more breathing room. I think I'd also increase the tracking on "• IDEAL RENOVATIONS •" to fill this area in a little more. Looks good!
Tom
jwash
Yeah
I actually had it that way but they wanted me to change it to the yellow I showed them in another example.
jwash
Pulskamp
maybe some wall?
I think I would like to see a bit of wall or something on the left, something to counter the figure and complete the idea.
Otherwise nice.
TheDesignShop
Overall - Good Layout
j
The problem with the design is, it's not strong enough. You have a construction worker with soft colors. Red & Yellow is always a tough combination to become effective. You did good on the copy by adding the black.
Black will add strength, and sometimes that's all that is needed. I changed the color of the guy to black and then I added a black out line to the background of the overall logo. I would probably change the white lines to black as well, I couldn't do it simply because the lines were too thin. I couldn't select them. I think if you did that, it would bring some good strength out in your design.
You may want to even play with the color of the top line of copy. I'd try it in black.
