When to add in a hourly rate
S
scarface
Guest
Luckily my overhead is an apartment and i have a home office/shop so my costs are low compared to alot of you on here. I used the ESTIMATE profit watch free software and it said my hourly rate needs to be $45/hr to meet my goals.
Now when exactly is a good time to add that in?
Lets say i have a coroplast or aluminum sign and i come up with $60 with vinyl and substrate on a random size of 2'x3', it may only take me 30 mins to mount the vinyl onto it so would i add in half of my hourly rate for mounting/install or the whole rate and do i do this for EVERY sign job or just bigger ones?
I'm just basically having a hard time figuring out where to insert the hourly rate at/what jobs to use it on because i do $12/SF for vinyl but should i add in the hourly rate for installing additionally?
Thank you!
Kottwitz-Graphics
If your using Estimate, the software does that for you...
Lets say your making this 2'x3' alum sign. When you start the estimate, you select the material your using, and input the size. It will figure the material costs (provided you have the correct cost info entered). When you add the vinyl your going to use and the covarage areas, that is all covered.
Now when you enter the info on the time to produce it, starting with design time, all the way down to production time, it will spit out the cost you shoud be charging to meet your goals. Don't forget to include the time it takes to select the vinyl off the shelf, load it into your plotter, weed, mask, and clean up (all relevant costs to this job).
On a side note, if your only charging a base rate of $45, I hate to tell you that you can be considered the lowballer in your area. Remember that your competitors do have higher over head, and one of these days, your going to want (or need) to move out of your home and into a more professional looking office. When you do that, your going to realize that $45 is not going to cover it, and your prices will have to rise, and you will loose a few customers. I did the same thing, but it wasn't too long after I started that I realized that working in a back room in my house just wasn't working. I (personally) had too many distractions with kids / tv's / the wife, to look professional. Luckly, I had an outbuilding, and with a lot of work, time and money, I made a nice office / work area.
DPD
Just a footnote in all of this that is typically forgotten with the cheaper signs (excuse my english).
I'll do this manually so stick with me on this.
Let's say your shop time is $45. That means that in one hour you need to recoup $45 to pay all of your expenses etc BUT.... there's nothing in your pocket.
Coroplast signs in my area usually run about $40+-. That means that to be competitive on a coro sign I'd have to basically design and build the sign in (using $45) in about 1 hour to break even - NO PROFIT.
Now, to make things worse. The latter was for an 18x24. Let say someone walks in and asks for a 12x18. Doesn't it still take basically the same amount of time to make the sign? Try telling someone that your 12x18 costs about as much as an 18x24.
When the guy down the street starts to sell his coros for $20 can you then match his price? Do you want to?
Food for thought although I"m sure others may have a different angle on this stuff.
Checkers
Kottwitz brings up a good point. Eventually, if your business does well, you'll either outgrow the appartment or be asked by your landlord to move out. So, plan for the move and charge accordingly to cover the expenses of a seperate location.
This will help soften the blow to your clients and reduce the chance of them leaving you when you have to make the move and be forced to raise your prices.
Checkers
beckys
and, u need to charge what the locals are charging...call around, block your phone, get quotes, -have a better idea of what to charge, and charge that, not much less cuz u live/work in an apartment.
