Where to edit Caldera edge registration marks
carlroger
Hi,
Running Caldera VisualRip+ 10.2, where do I change the space between the edge registration marks? I simply can't find the setting anywhere.
/Carl
balstestrat
Problem Solver
Such an old version I'm not sure if the place is the same.
When you go to the cutting tab, you select your cutter, there is a "Tools" button I think. There should be all the settings about the marks.
