White ink on Epson s80600
cmxdigital
I need to print pure white stripes on clear vinyl. I'm looking at the Epson 80600. How "solid" is the white. I mean, if you hold it up to light, can you see through it?
Thanks for any and all thoughts
Dave O'Dell
ProColorGraphics
I don't have white on my S80, but do on my S70. It works good for a backfill behind color, but is definitely NOT opaque. It is quite transparent. You will want UV if you need it close to solid.
fastmax
true, i have an s70 and roland LEJ, u can get the s70 to print white very fast and as opaque as translucent white vinyl. the LEJ UV printer can be opaque but it takes alot of ink , overprinting maybe 5 times id say
jfiscus
Rap Master
White is as opaque as white ink can be. Which isn't that opaque, more like a translucent white vinyl. Even white print vinyl needs a gray backer/adhesive to be a block-out vinyl. It DOES 100% knock-out reflective though, FWIW.
Attachments: Epson White Ink on 3M 8150 Clear Vinyl with 3M Optically Clear Laminate.
17991393_1487970827902371_800434618083108882_o.jpg 35694770_1926506044048845_5013249186972303360_o.jpg 35789911_1926506060715510_5054975283879215104_o.jpg
Joe House
Sign Equipment Technician
This is all pretty subjective here. Your best bet would be to ask a dealer for a sample print of what you're looking for. And while they're at it, ask them to time the print so you know how long it takes to get the results you're seeing.
Good Luck
jfiscus
Rap Master
Epson White on IJ680CR-10 Reflective wrap.
jfiscus
Rap Master
Depending on your RIP, there are quite a few different ways/speeds to run the white ink at. At first we only ran it on some super slow stock profile, but you can change the passes, etc in the RIP settings and it is about twice as slow as a normal print. One head can print the white and the other can print the color overlay, or vice versa. Setting up the artwork can get kinda confusing as to what all is overprint or not, but it isn't that bad once you get it figured out.
