J Hill Designs
OK so I have been having this problem for a while now...Magenta nozzle check will be fine right when I turn on the machine...run a clean, and it goes to crap (like 20% firing correctly)...
I swapped supply lines C with M to see if it was a supply issue...nozzles performed beautifully on both swapped heads..before and after a few cleanings...
Swap them back, do a clean, and M goes to crap again...
I cant see it being supply, because magenta came in fine on the C head...
I cant see it being capping, because cyan came in fine on the M head...
I can't see it being the head because again cyan came in fine when switched...
Any thoughts?
Please disregard Lc and Lm...those are known issues..
Hope pics are clear enough, and TIA
Any thoughts?
