Window Perf
joshatvideoplus
I have a Mimaki UJV-160 and am having difficulty with window perf.
I am new to this so I am probably just not doing something right.
The problem is that the ink is curing between the holes on the perf and I have tried several tings to no avail. Any advice will be greatly appreciated.
MikeD
when you pull the perf off of the liner, does the ink still clog the holes, or does it stay on the liner? You may have luck switching to a different liner that retards UV ink...no idea what type of liner that would be though.
Good Luck!
joshatvideoplus
Mike it does stay clogged in the hole, I am using a different brand then I tested on the machine, the other brand worked it had a clear plastic like liner, what I have now is some kind of coated paper.
MikeD
that makes sense.
Hopefully you can transition back to the material you tested without hurting your profit.
