Wrapping around door handle - man door
smksr
Good Afternoon All.
What tips and tricks can you recommend on how to wrap around a door handle on a man door? I inserted an image of what the prior sign company did and it was rough. Thanks in advance.
unclebun
A sign company did that???
Must be the one that bid half what everyone else did.
Easiest is to remove the door handle before wrapping. Even if you don't, you can successfully wrap around it and get right up to the trim ring, as well as fill all the way to the edge of the door.
But considering they got creases and wrinkles on the flat areas....
